HELP!! please i have code 18 CAR WONT RUN!!
Old Feb 7, 2004 | 05:19 PM
97ramairtransam's Avatar
ok i have gotton the code ,its a code 18 which is crank signal open or no signal(ive been told that it is injector probelem well heres the deal!!. car ran perfect for 50 miles after a new motor, then one morning i went to start it and it just hit and miss, and id smell alot of gas, anyways when it finally started it would rev very slow!!and not idel, and most the time not start! well now it wont start at all, and will just hit every now and then. its got so much gas now,it got into the oil, so i changed that, and now im stuck with a code 18 i took the fuel rail off to see if an inector was maby stuck open but its not!! how can i test them to see if there right? i need help!!!like i said car will not start now, i deleted the code from the scanner and it came right back when i cranked it
Old Feb 7, 2004 | 05:45 PM
The pcm is picking up an injector or wiring fault. With the key ON, make sure there is power to the pink wire that goes to each injector. The other wire receives a ground from the pcm to fire the injector. That can be checked with a "noid" light. Injectors can be tested with a meter to verify the resistance is ~12 ohms.
cmdeshon
Dec 27, 2014 10:06 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Dec 1, 2014 08:08 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
