Help Please...crank pully WILL NOT come off!
Old Jan 3, 2004 | 01:06 PM
ShelbyZ28's Avatar
Hey guys I need some help here. I'm in the middle, or I guess the beginning of my opti install. For the past hour I have been trying to get my crank pully off and it won't come for anything. I've tried everything I can think of. I tried using a pully puller thingy and it won't budge. I must be doing something wrong. Any help is greatly appreciated I'm about to give up and pay someone to do this
Old Jan 3, 2004 | 01:13 PM
Hyperspeed97z28's Avatar
your at the hardest part of the install.. take a breath.. Take the 3 bolts off. soak the area with some pb blaster or something equal and work it off with your hands. it will come.. took me about a half hour to get that damn thing off when I did my opti.. I removed it with my hands and a hammer, LIGHTLY tapping it to budge it a lil. push n pull. it will come....
NXz28's Avatar
to get the crank pulley off, leave the crank bolt screwed in, then take off the 3 bolts that hold the crank pulley to the hub. next use a 3 way- gear puller to remove teh pulley. it will come on, don't worry.
Old Jan 3, 2004 | 01:14 PM
Dont know if you've seen this link or not but it helped me out ALOT... http://www.streetillusionsracing.com.../opti/opti.htm
Old Jan 3, 2004 | 01:15 PM
NXz28's Avatar
takes about 1-2 minutes to take off if you simply use a puller...
Old Jan 3, 2004 | 01:18 PM
Hey now not all of us got the tools! We gotta work with what we have.
Old Jan 3, 2004 | 01:19 PM
ShelbyZ28's Avatar
Yeah I've got that plus another guide printed off plus a Haynes manual. I soaked it will some PB blaster earlier so I'll let it sit awhile. The puller I used was a 2 toe puller, is it necessary to use a 3 toe one?
Old Jan 3, 2004 | 01:20 PM
I've herd alot of people have problems with the puller as well as doing it by hand... I say use the hand method only because thats what worked for me and I didnt even have a pulley puller.... Good Luck. Let us know how u make out..
Old Jan 3, 2004 | 01:23 PM
AsianSensation's Avatar
96-97 requires an harmonic balancer puller. Makes your life alot easier.
http://www.97ta.com/lt4/lt410.jpg
Old Jan 3, 2004 | 02:16 PM
v7guy's Avatar
The first time I did this...many years ago LOL i sepnt a week trying to get the pulley off, tried pry bars, hammers, by hand etc, nothing worked, and I would literally try for a couple hours everyday for 5-6 days straight, it wasn't until I spent the 20-25 on the three claw puller that it came off with almost no effort in about 2 minutes, I was pissed, and really excited all at the same time.
I fyou want it off and don't want to struggle go get the gear puller.
Old Jan 3, 2004 | 02:26 PM
ShelbyZ28's Avatar
Thanks I guess I'll go out and buy a three claw puller tonight and go at it again tomorrow morning. I just tried for another 1/2 hour with a two claw with no luck . Thanks again I'll let you know how it turns out.
Bryan
Old Jan 3, 2004 | 02:37 PM
Normally the pullies on the late models have bolt holes where you can use a puller like Asiansensation showed. Earlier models can come off this way. The late model pullies have the holes I am talking about at the same place where the claws are in my pic.
You might be able to get it off with a two claw puller if you turn the claws inside out and can get it straight across between the spokes on the inside of the pulley.
Old Jan 3, 2004 | 02:48 PM
v7guy's Avatar
that was a good suggestion, with the force applied on the inside you might you have better luck. Something else to try if you get bored before grabbing the 3 claw
Old Jan 3, 2004 | 02:55 PM
ShelbyZ28's Avatar
Thanks Shoebox that picture will help. I'm going to pick up a three claw puller now. Thanks again for all the help guys I appreciate it a lot
colts0455
Jul 7, 2015 07:19 PM
Snoman73
Nov 17, 2014 07:22 PM
vhgjk123
Aug 16, 2002 11:53 PM
vendela99
Jul 10, 2002 12:53 PM
