help please
Old Feb 24, 2006 | 06:24 PM
194bird's Avatar
help please
ok i had atune so it would get rid of some codes put it on started the car light went off then came back on checked it was a code 42 so i repl the opti wires and put some njktr6 becouse i am tryin to get it ready for the spray but started the car up today and same thing so i un pluged the msd box light went out but now the car is surging about 4500 up it does not matter if its at wot or just slowly accelarting thanks for any help
Old Feb 24, 2006 | 07:54 PM
GreenDemon's Avatar
Re: help please
No offense man but I can't really understand what you're saying other than your engine isn't running right and you have a code 42 set.
Old Feb 25, 2006 | 09:11 AM
Re: help please
DTC 42 involves a lot more than the Opti. There is a detailed analysis sheet in the shop manual showing the steps required to rule out each component. Get a copy of the chart and work your way through it. IC Module, shorts or grounds in the wiring, etc.
What codes did you have before the "tune"?
What did the "tune" consist of?
What did you "put on"?
What year is the car?
What are the mods on the car?
Very hard to answer a question without all the background.
I don't think people realize how much lack of punctuation and capitalization makes their posts almost incomprehensible. A lot of people will look at a post like this and not even bother to respond.
