Help please
Old Aug 10, 2005 | 07:33 AM
SloLt1Z's Avatar
Help please
Ok here's the issue i have a supercharged 95 z, the fuel pressure is falling off unfer boost. I put in a new regulator, and pump and still it's galling off to 40 lbs under boost. We are supposed to be leaving for the track tomorrow
Old Aug 10, 2005 | 07:56 AM
Re: Help please
How does you S/C system add the extra fuel? Does it have an FMU? Or are you running an S/C tune on the stock PCM?
How much boost are you running? What size injectors?
Have you changed the fuel filter?
Old Aug 10, 2005 | 08:26 AM
SloLt1Z's Avatar
Re: Help please
stock pcm with a s/c tune, 60 lbs injectors, 15 psi of the boost. And i forgot about the filter but i'll change it after work.
Old Aug 10, 2005 | 09:30 AM
Re: Help please
Assuming then that the FPR is boost referenced. Have you checked the boost pressure line to the FPR to make sure its not leaking?
Old Aug 10, 2005 | 10:26 AM
SloLt1Z's Avatar
Re: Help please
Yes it is not leaking. I put a new one on it.
Old Aug 10, 2005 | 04:29 PM
SloLt1Z's Avatar
Re: Help please
ttt
Old Aug 10, 2005 | 04:45 PM
Re: Help please
How big is the pump? Brand?
When you said "Yes it is not leaking. I put a new one on it." did you mean you put a new boost reference line in, in addition to a new FPR?
Old Aug 10, 2005 | 05:24 PM
SloLt1Z's Avatar
Re: Help please
The pump is a walboro 340 and yes i meant the reference line sorry i was at work and rushing
Old Aug 10, 2005 | 09:44 PM
SloLt1Z's Avatar
Re: Help please
ttt
Old Aug 11, 2005 | 06:45 AM
SloLt1Z's Avatar
Re: Help please
ttt
Old Aug 11, 2005 | 08:41 AM
Re: Help please
Please don't "TTT" more than once in as 24-hour period - see "sticky" at top of forum.
The Walbro 340 is a 255LPH @ 435psi pump. With the kind of BSFC you need to run with a high boost S/C application, it would be good for no more than roughly 760 flywheelHP. With 15# of boost and dual I/C's I would assume you are making at least that kind of HP. Possibly the pump isn't large enough.
Have you considered posting this in the "Forced Induction..." forum?
