help!!! passenger side header removal?
Old Mar 6, 2006 | 07:30 PM
4SFEDZ's Avatar
Angry help!!! passenger side header removal?
man im stuck! ive got everything, un bolted, but i cant get it to slide out. does it come out the bottom or top, ive tried both, ive got the altenator, starter off, i thoght about taking un bolting the motor mount but cant get to it.....................help
the car is a 94 lt1 m6 with jet hot long tubes.
Old Mar 6, 2006 | 07:37 PM
blacknsilverz's Avatar
Re: help!!! passenger side header removal?
did you take out the oil dipstick and it comes out the bottom that is how i got my headers out just play with it and it will come out that side is a bitch to work on
Old Mar 6, 2006 | 07:42 PM
4SFEDZ's Avatar
did you have to jack up the motor any? if so how did you get the motor mount unbolted? how does the dip stick come out? i didnt even look at it.
Old Mar 6, 2006 | 07:46 PM
Brettinator's Avatar
You need to carefully (stress carefully) get the car up on jackstands as high as safely feasible first off. You can get to the motor mount on the passenger side, remove the starter of course, and once you get the bolt out jack the passenger side of the engine up about an inch maybe a little more, the Jethots will feed down from the bottom at a pretty high angle not quite vertical but you'll see. If you had access to a lift that would be the safest and best way. I didn't as do many so I had to install mine from the bottom on the driveway but it took some tall jackstands.
Good luck
Old Mar 6, 2006 | 07:49 PM
4SFEDZ's Avatar
Good luck
i got it jacked up enough where i can get under it easily, i unbolted the single motor mount bolt but there was not enough room for it to slide out, it hit something b4 it could come all the way out.
Old Mar 6, 2006 | 08:05 PM
Man wish I could "beam me up Scotty" over there and help you, it's hard over text to get the full picture. It may take a couple inches jacked up, I'm sure your spark plugs are removed, it shouldn't be hitting the ac pump but might check, all that is remaining is the kmember and block clearancing, it should slide right out, it definitely comes out like it goes in through the bottom. Your AC lines shouldn't be hitting they are up higher by the front shock mounts. I'd say check the acpump and remove it if you have to (shouldn't have to though). Wish I could help you more man.
Old Mar 7, 2006 | 10:31 AM
96_pimped_out's Avatar
I didn't have any trouble with mine.... well, I guess it made it easier since the heads were off when I set them in place. I'd recommend that approach!
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
blue89iroc
Jul 26, 2002 04:56 PM
