help!!! passenger side header removal?
man im stuck! ive got everything, un bolted, but i cant get it to slide out. does it come out the bottom or top, ive tried both, ive got the altenator, starter off, i thoght about taking un bolting the motor mount but cant get to it.....................help
the car is a 94 lt1 m6 with jet hot long tubes.
Re: help!!! passenger side header removal?
did you take out the oil dipstick and it comes out the bottom that is how i got my headers out just play with it and it will come out that side is a bitch to work on
You need to carefully (stress carefully) get the car up on jackstands as high as safely feasible first off. You can get to the motor mount on the passenger side, remove the starter of course, and once you get the bolt out jack the passenger side of the engine up about an inch maybe a little more, the Jethots will feed down from the bottom at a pretty high angle not quite vertical but you'll see. If you had access to a lift that would be the safest and best way. I didn't as do many so I had to install mine from the bottom on the driveway but it took some tall jackstands.
Good luck
Good luck
Good luck
Good luck
Originally Posted by trouse40
i got it jacked up enough where i can get under it easily, i unbolted the single motor mount bolt but there was not enough room for it to slide out, it hit something b4 it could come all the way out.
Jul 4, 2005 05:00 PM
