Help! OTVC wire problem and Plugs smell like oil and fuel.
I just bought some really nice pre-made OTVC wires from elite and I am having a hard time putting them on. Is it possible to install these on stock maifolds? Please say yes~!!!
Also, I pulled my old plugs (drivers side only so far) and all 4 were black, black, BLACK... smelled of oil and fuel and were kind of wet/damp. I had a HORRIBLE misfire and felt as if I was literally running on 3 cylinders. That is why I'm installing new plugs and wires... I'll get a pic up soon of the plug.
Previous to the misfire trouble/history: Rebuilt motor with new block, had the car running and adjusted the valves with the car on. Had a fuel leak, replaced injectors, regulator and fuel rail. Car still starts hard as if there is a leak and running worse than it did the first time I fired it up after the rebuild.
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
