I just bought some really nice pre-made OTVC wires from elite and I am having a hard time putting them on. Is it possible to install these on stock maifolds? Please say yes~!!!
Also, I pulled my old plugs (drivers side only so far) and all 4 were black, black, BLACK... smelled of oil and fuel and were kind of wet/damp. I had a HORRIBLE misfire and felt as if I was literally running on 3 cylinders. That is why I'm installing new plugs and wires... I'll get a pic up soon of the plug.
Previous to the misfire trouble/history: Rebuilt motor with new block, had the car running and adjusted the valves with the car on. Had a fuel leak, replaced injectors, regulator and fuel rail. Car still starts hard as if there is a leak and running worse than it did the first time I fired it up after the rebuild.
otvc wires are more meant for headers. May have a hard time routing them with stock manifolds... I could be wrong though.
Damnit, I cant believe I didnt know that.
I must be the only person to do this. :/
Well ya know I know of a fix to make them easier to put on... get some headers
what are valve guides and how do you replace them?
