Help! oil pan wont' drop
Old Mar 10, 2004 | 10:53 AM
JJ's95B4C's Avatar
I was able to take the timing cover out by slowly prying it out and nothing happend, but i still want to drop the oil pan so i can install it back. I loosened the first 3 bolts on each side, and it won't budge. Do i have to loosen more bolts for it to drop? Should i stick a scredriver in there to try and pry it down? help please!
Old Mar 10, 2004 | 10:59 AM
2MCHPSI's Avatar
loosen all of the pan bolts and also remove the oil level sensor. This should allow you to drop the pan
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
