Help needed, SLP shortie issues
Old Jul 1, 2006 | 05:49 PM
Unertl42's Avatar
I bought the headers from another user, so they didn't come with directions. I have a 96z28, and I can't seem to get the drivers side in. What needs to be removed in order to get it in.
Old Jul 1, 2006 | 06:25 PM
snorkelface's Avatar
Re: Help needed, SLP shortie issues
If you go to SLP's website, they should have some directions for you to download from there. If not, they can send them to you.
Old Jul 1, 2006 | 06:47 PM
Another Red Z's Avatar
If you have the single cat headers you need to disconnect the steering shaft at the rack.There is a small bolt , 10-12 mm that needs to be loosened.You also need to take off the oil filter.They go in from the bottom and there is not much room.
Old Jul 1, 2006 | 07:06 PM
shartflhs's Avatar
I had to unbolt the drivers side motor mount and jack the motor up a little bit. just pull the through bolt, dont unbolt the mount from the block. I also bought a set from another member and had no instructions. Thats the only thing out of the ordinary i had to do. no playing with the steering.
Parts Wanted
Mar 17, 2015 11:24 PM
slocody
Feb 10, 2003 01:04 PM
NED4SPD
Sep 16, 2002 10:45 PM
turbo_Z
Aug 19, 2002 10:50 PM
mjcent922
Jul 27, 2002 12:42 PM
