Help needed on 96 z28
Old Nov 30, 2007 | 08:35 PM
mpsalmon's Avatar
The car is having problems starting. Once it does start you have to be really gentle with the throttle otherwise it will stall out. The car will rev up and drive, but if you give it a sudden throttle it will stall out. What could this be. I replaced the map sensor, but that did not have any effect. I cleaned the Maf sensor but that did not have any effect. The only thing i know to do is to take it to the diagnostic machine to get the solution. It is not shooting any engine codes.
Old Nov 30, 2007 | 10:02 PM
BBZ's Avatar
BBZ
I had a MAF sensor go bad and thats how it ran.
Old Nov 30, 2007 | 10:46 PM
96m6lt1's Avatar
check your fuel pressure.
check injector fuse.
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
