mpsalmon |
11-30-2007 08:35 PM |
Help needed on 96 z28
The car is having problems starting. Once it does start you have to be really gentle with the throttle otherwise it will stall out. The car will rev up and drive, but if you give it a sudden throttle it will stall out. What could this be. I replaced the map sensor, but that did not have any effect. I cleaned the Maf sensor but that did not have any effect. The only thing i know to do is to take it to the diagnostic machine to get the solution. It is not shooting any engine codes.
