Help! Need Opinions
Old Oct 21, 2005 | 09:25 AM
Dfetter84's Avatar
Help! Need Opinions
was assembling the motor last night on the stand and snapped 2 of the optispark bolts.
Cant find them at the dealer
not sure if i should tap the timing cover
not sure if they snapped in the block or in the sleeve of the timing cover
need opinions on how to fix
ANYONE have these bolts????
Old Oct 21, 2005 | 10:57 AM
Crazy95Z's Avatar
Re: Help! Need Opinions
You can find replacement bolts at any local hardware store. I'm not sure on the size or thread pitch but I know we had to do the same thing on a buddy's motor not to long ago. Pull the timing cover and oil pan back off and see how much you have to work with. Some vice-grips usually work nice, if it's too deep to get any on it, then you can try eazy-outs avialible at Sears but I've never had much luck with those. Last resort would be taking it to a machine shop and they can drill it out and put a heli-coil in for you. Last time I had to do that was on a Dodge 360 Intake and was about $35.
Old Oct 21, 2005 | 01:39 PM
Dfetter84's Avatar
will i need to replace the seals/ gasket on the timing cover
and the oil pan rubber gasket(1pc)
Old Oct 21, 2005 | 01:44 PM
HardcoreRM125's Avatar
If your just assembling the motor and its already a new gasket, then no.
If not, then Yes you should. Its cheap insurance. Easier to pay the money now for a gasket than to pull the motor out once its up and running because it leaks
Old Oct 21, 2005 | 02:06 PM
Dfetter84's Avatar
Yea shes a fresh motor
ill be changing my signature when it runs
i just dont wanna have to drag the motor back to the machine shop
all the seals and gaskets arebrand new
Old Oct 22, 2005 | 06:00 PM
Dfetter84's Avatar
I GOT IT
vise grips worked
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
birdblack
Jul 8, 2015 07:23 AM
