Help: Need help witha mis-fire.
Old Feb 27, 2005 | 11:36 AM
RyanB58's Avatar
I just replaced the OPTI, water pump, plugs and put in Taylor OVC kit. I also removed the air pump which I did not do when I installed the headers a month ago. It starts fine, but I have to hold it at a 2000 RPM to keep her running. I can stab the throttle and it is fine, but if I let it fall below 2000 it dies or if I roll the throttle up to 3000 it willmis-fire badly. Any ideas from you would be appreciated.
Old Feb 28, 2005 | 05:28 AM
slopokrodrigez's Avatar
Re: Help: Need help witha mis-fire.
Plug wires crossed up?
Old Feb 28, 2005 | 10:44 AM
RyanB58's Avatar
Nope, I checked that. I am picking up a new coil tonite. I think that is it.
Will Update. Thanks for replying!
Ryan
Old Feb 28, 2005 | 12:15 PM
teke184's Avatar
bad maf?
try unplugging it...if it runs ok it indicates that is the problem.
sure you don't have a hole in the intake someplace...like a ripped elbow
Old Mar 1, 2005 | 12:11 PM
RyanB58's Avatar
I let it run for a bit and it pulled a MAF code so i bought a new one. I will not get to work on it till Wednesday, but i will update. I doubt it is a ripped elbow, but i will check.
Ryan
derek83z28
Mar 15, 2005 06:37 PM
Klypto
Mar 3, 2005 07:35 PM
Klypto
Advanced Tech
Mar 2, 2005 11:51 PM
mdstud
Feb 8, 2005 02:56 PM
