Help with my RR
Old Feb 16, 2005 | 12:20 PM
97SLPcamaroSS's Avatar
Help with my RR
Ok i have a LT1 and im running the Lt4 gm peformance hot cam kit with springs 1.6 roller rockers and shuch and guy mentioned to me that i still have to lash the rockers to zero but i cant just tighten them down to achive zero lash. Can anybody help me.
FYI its the RR that have the set screw to keep the bolt/shank from backing off.
Thanks Kyle
Old Feb 16, 2005 | 01:42 PM
Re: Help with my RR
You would probably have a better chance of getting a quick response on the "LT1 Engine Tech" forum. Moving it there......
Old Feb 16, 2005 | 01:51 PM
sssalah's Avatar
Re: Help with my RR
Why can't you tighten the adjuster nut? didn't you loosen the set screw all the way? you should do that and then tighten the nut by hand until it touches the rocker and thats about zero lash, you can confirm by rotating the pushrod while tighting and when you feel drag that is your zero lash.
Old Feb 16, 2005 | 02:05 PM
BUBBA's Avatar
Re: Help with my RR
When you get your answer, please also let us (me) know what your mods are to give you 401 RWHP.
Old Feb 16, 2005 | 02:07 PM
Re: Help with my RR
I just got everything in today its all in pieces i was just laying it out for everbody thanks for the help. Kyle
Old Feb 16, 2005 | 02:43 PM
Re: Help with my RR
Well my car came factory with 310hp then i added Nitrous, ele water pump, under drive pulleys and a few other tricks like computer mods and major trans work
And that figure was on the dyno without all the parts i just bought installed
Old Feb 16, 2005 | 03:19 PM
BUBBA's Avatar
Re: Help with my RR
THX.
