Help meeee
Old Apr 24, 2013 | 09:30 PM
Fonzy1315's Avatar
Unhappy Help meeee
Hi everyone I come for ur help I have a 97 Chevy camaro z28 that I been having crazy problems with it due to a misfire it's been in the the shop for a month and couldn't find the problem they changed the plugs wires and everything then they checked the fuel pressure and its at 40 psi but when he shuts it off it doesn't hold pressure it's droppeds pretty fast and sometimes it struggles to start some one please help me
Old Apr 24, 2013 | 11:10 PM
slick1hunting's Avatar
Check the vacuum line off of the fuel pressure regulator for fuel in it. If there is thats your leakdown. If no fuel coming out it on the leakdown could be checkvalve in fuel pump or injectors. The checkvalve wont create much problem but a leaky or bad injector can. You could pull the fuel rail and injectors up and inspect that. Did they scan it for codes and if so are there any? Some codes do not set a light. Was the 40 psi fuel pressure with the vacuum line disconnected and at idle or???
Posted from Camaroz28.com App for Android
dillonmk
V6 Tech
Apr 22, 2011 11:21 AM
Speed Density
Parts Wanted
Jun 25, 2008 11:55 AM
keith1333
Parts Wanted
Nov 15, 2007 08:36 AM
matt95camaro
V6 Tech
19
May 12, 2005 06:07 PM
SBainsTA
Pacific
Mar 24, 2004 10:12 PM
