help me run 13.1-.5
You're probably not far off, try:
-drag radials
-throttle body coolant bypass
-160* thermostat
-cold air induction kit
If you're still on the edge, you could do a stall converter as well and/or a gear swap (if you've got 2.73s).
-drag radials
-160* thermostat
Full exhaust, CAI, and DRs should be all it takes. Hopefully you'll be luckier than me. I should be running that time easily but I hit a 13.8 wall and lost 3 mph by adding LTs yet running the same 13.8 add a few hundredths and I have to figure out why my car is down on power.
Its not hard, Jon94Z went 13.58 with just a Borla and Cold Air, he was on regular tires, no Nittos. The car went 2.0 in the sixty, stock converter and stock 3.23 Gears. He took out the back seats and had like a 1.4 tank of gas when he did it. But I was looking at his time slips, weather and track prep play a huge part. Get a converter since your getting tires
Just the Longtubes, cutout, and CAI got me the times in my sig. I havent been back since. Full exhuast and CAI will get you there or you can do gears, drag radials, and CAI should get you low to mid 13's fairly easy. Do both and you could pop some high 12's if you can cut a sub 2 sec 60ft time. Unlike me
But some BF DR's will soon be here to fix that problem and prepare me for this fall
The conditions were not the same. I ran in April and got my 13.80. In May on a fairly cool day I trapped 103.7. Last week when I ran it was quite cool out and humidity might have been up a tad but the air didnt seem that heavy. There was an oil spill in the lane I was forced to run in during the bracket races. Even with those conditions I wouldnt think that would account for a huge loss in mph, or would it? My LT4 KM will be in tomorrow and I'll see if that helps now but I'll need it sooner or later anyway.
