Help me pick a cam Please
Old Apr 12, 2010 | 04:14 PM
jnordjr's Avatar
Hi, I think I have a lifter ticking so i think I will just do a cam swap too. I have a 95 Z T-56 with a set of ebay ported and polished LT1 heads with 2.02 and 1.60 valves, headers and full exhaust, MSD 6a, cold air, stock TB with air foil, 3:73 rear, and a nitrous works plate kit. Right now i have a CC306 which i don't really like and before i got the juice and heads i had a hot cam that i liked. So i'm just looking for a few opinions on the next cam. thanks
Old Apr 13, 2010 | 10:01 AM
extreme79z's Avatar
I think after p&p heads you will come to like that 306 more... However without knowing the quality of the port work it's hard to tell how much better than stock you are going to be. Who did your tune on your 306? MadZ28 handled my tuning needs in the past and has done me really well. My bolt on Z28 was trapping 106 in the 1/4, with only Borla exhaust, Moroso cai, and 3.73 gears. I was quite impressed by the way the car ran, and would refer anyone to one of his tunes.
Old Apr 13, 2010 | 12:35 PM
Hal Fisher's Avatar
You may do all that and still have the lifter tick. I changed lifters and still have it on the same port (3 intake) I think some just have bad passages to certain lifters.
Hal
Old Apr 13, 2010 | 02:14 PM
jnordjr's Avatar
I already have the heads on, and i just think the 306 is a big number cam, they say to get the power out of the 306 I need to rev it to 6900rpm and i don't, I think thats to high for the stock 2 bolt bottom end. I rev it to 6300. I want more torque. I also had ion tune my car, never on the dyno, but he said i might get 15-20 horse on the dyno so i figured i would wait, his tunes are real good i think. I might just call lyod elliot for a cam, nut again any opinions are appreciated.
Old Apr 13, 2010 | 02:19 PM
jnordjr's Avatar
As for the tick, I'm just trying to eliminate things. It all started after i put the nitrous on with a button on the shifter ball. The problem was because of the wires in the ball i couldn't tighten it down all the way and it was loose. I was slammin gears and i got 2nd going for 4th, i caught it right away, but now it is ticking.
Old Apr 13, 2010 | 02:40 PM
RUDEDOG's Avatar
If you want more torque down low check out the numbers on the cam in my sig and try to find something close to that. I'm happy with it. Good luck on isolating the tick.
Old Apr 14, 2010 | 12:39 PM
jnordjr's Avatar
Any body have a good lyod elliot cam?
Old Apr 14, 2010 | 01:09 PM
95zsean's Avatar
I like my 503 and from what i read it likes Nitrous. I'll let you know how it likes it in a month when I get it on, and working.
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
skittlez87
Dec 29, 2014 03:23 PM
siguy
Nov 27, 2014 10:07 AM
