Help me pass emissions
Old Jan 10, 2007 | 12:36 PM
blaze309's Avatar
I can't seem to pass emissions and i'm not sure what else to replace.
here are the readings
Hc: 467 Limit is 220 - The lowest i've got it to is 366 and that was because i put some alcohol in the gas tank.
Co 0.64 Limit is 1.20 so it passed
So far i've replaced both o2 sensors, plugs, wires, and optispark.
I'm thinking it could be the cat clogged but im just trying to pinpoint what it is so that I don't spend more money then i need to. Ohh and i am throwing a code but that's for the abs because one of the wires got messed up.
Old Jan 10, 2007 | 02:58 PM
RKPsk8er's Avatar
it could be your EGR. magnaflow cats are only like 80 or so. Im in the middle of the same problem too.
Old Jan 10, 2007 | 03:02 PM
Jazsun's Avatar
I have a magnaflow cat if you wana buy it. MAke an offer. ITs brand new for a single cat 93-95 car.
Old Jan 10, 2007 | 06:47 PM
razor02097's Avatar
The moron who tested my 94 wouldn't shift to 3rd gear and it failed the test. I just drove around and got into another bay and it passed fine.
Old Jan 10, 2007 | 07:44 PM
94 NO TOP Z's Avatar
Do you have the fans at the stock setting? That usually helps also.
Old Jan 10, 2007 | 08:27 PM
BoozrCruzr's Avatar
Go through with stock tune, and the stock 180 t-stat. If you don't pass test your cat conv with a heat gun. It should be about 100 degrees hotter (or more) after the cat than before it. If you need to buy a cat, make sure you get a 3-way cat!
Remember to drive around for 100 miles or so to burn the manufacturing oil out of the new cat.
Chad-
Old Jan 10, 2007 | 08:32 PM
ZL1modified's Avatar
no spending imit in TN?
i know that in PA you get an exempt sticker if you have put at least 150.00 into getting it to pass...
Old Jan 10, 2007 | 09:47 PM
sbs's Avatar
sbs
Every place I've lived, including PA, that type of exemption only applies to fixing legal parts that are broken and weren't tampered with.
If you've fubared the emissions by tampering (like changing fan temps) or installing "offroad-only" parts (like the hotcam) then there is no limit on how much you'd have to pay to fix it.
Although, the inspectors I've used in PA don't seem terribly knowledgeable, so I wouldn't be surprised if you could get away with it.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
