Help me Pass emissions!
Old Aug 1, 2006 | 07:20 PM
TobyZ28's Avatar
Just failed emissions, again! I have a hunch its an O2 sensor but here are my readings, hopefully someone can help...
HC 0.5335 / 0.5000
CO 0.0486 / 9.3200
NOx 1.1606 / 1.2400
So it looks like im running lean, CO is suuuper low. HC Failed, NOx was close to failing as well Car was well warmed up for the test.
I just put MAC's on a few weeks ago (i was failing before them too) and put an almost new GM Cat on. Changed the plugs as well while in there. EGR was swapped out maybe 3 years ago too.
Old Aug 1, 2006 | 08:01 PM
Robs97Z28's Avatar
Re: Help me Pass emissions!
did you have the ecm retuned for 30# injectors? if not, I would start there.
did you remove the air pump?
Old Aug 1, 2006 | 09:36 PM
TobyZ28's Avatar
Yes Air pump has been removed, and the cars definatly been tuned for the SVO 30#'s. The car was warmed up for 20ish minutes and sat idling at hte test center for another 20 minutes or so. It was definatly way warm.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
