Help me hit 12s please...
Old Apr 30, 2003 | 03:51 AM
JeremyKweens's Avatar
With my mods now I figure im running solid 13.8s - 14.2s or so. I would like to be running high 12s or less, what mods should I do. Heads, cam and gears?
any other suggestions?
Old Apr 30, 2003 | 04:02 AM
Fastbird93's Avatar
You know, looking at your mods list, you have about as much as a guy I know who runs 12.8x @ 108.xx. You should me mid-lower 13's with the exhaust and headers as you sit right now. Get that thing to a track and get some good ideas where you're running.
Old Apr 30, 2003 | 04:28 AM
magius231's Avatar
these cars run solid 13.8 - 14.2 bone stock...I would almost expect you to be able to manage a 12 as it sits if you can get a good low 60' time
Old Apr 30, 2003 | 08:16 AM
teke184's Avatar
i agree with the above. granted you may have to battle a bit higher elevation than some (not sure how high you are).
i'd say your next step should be TRACTION. get some lca's, brackets, and maybe a torque arm or at least a poly torque arm bushing, and then some good sticky tires. and if you aren't too concered with road manners, maybe some drag shocks for the rear.
some other smaller things to do before ripping into the top end would be a good computer reprogram (madwolf or pcmforless), some good weight reduction, 85mm Z06 maf (arguable gains), and an electric wp.
a bit more involved would be some 1.6rr
but as i said, traction is your biggest concern now.
Old Apr 30, 2003 | 01:12 PM
atljar's Avatar
You should be fairly close right now.
I had pretty similiar mods to you (long tubes however and gears) and ran 13.1 (12.76 SAE corrected times). Go run her and see how she does. A great launch is the key.
Old Apr 30, 2003 | 01:29 PM
jcolez28's Avatar
The only way is through nitrous. All those other mods only get you .5 at most.
Old Apr 30, 2003 | 01:36 PM
Gripenfelter's Avatar
Good 1/4 mile times are all in your 60 foot.
How hard you launch off the line and how well you hook.
Old Apr 30, 2003 | 01:57 PM
revtime's Avatar
I ran a 13.6 at the end of the season last year. I have not ran this year yet cause the car is apart for tranny rebuild.
Without headers and no internal engine mods, just 3.73,s and Ed Wright tune, 2.1 sixty foot time on Potenza RE730,s.
Traction is the key you should be running low 13,s with your mods.
Old Apr 30, 2003 | 02:30 PM
TMDZ28's Avatar
Re: Help me hit 12s please...
75 shots of NX kits, and you all be set
Old Apr 30, 2003 | 02:37 PM
IrocManiac's Avatar
Those mods you have should get you real close if you're not already there. If you're only running a 13.8 to 14.2 with those mods you've got some problems...
Old Apr 30, 2003 | 02:40 PM
GREGG 97Z's Avatar
You say you figure you should be running high 13's, is that just what you think it will run or what it has actually run? You could be at least in the low 13's with your mods as it is assuming you can drive pretty well. With a good 60' (2.0 or better) I'd bet you would run low 13's at least. I along with many others reached the 12's with just bolt ons - no cam or head work.
Old Apr 30, 2003 | 02:41 PM
IrocManiac's Avatar
What mods do you have?
Old Apr 30, 2003 | 03:07 PM
GREGG 97Z's Avatar
mods
Old Apr 30, 2003 | 09:20 PM
Bone stock the best I could get outta of it on gtech was 14.4. I am at a really high elavation here....so ya that doesnt help. I was thinking about getting some Nittos this summer...but I am not to sure yet. I dont want to get nitrous becuase its not my style.
Thanks for the help fellas
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
