Help me find where the smoke is coming from
Old Jan 31, 2004 | 09:52 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Already did a leak down on the motor. 2to3% at the most. So that's telling me that the rings and valves are ok. The motor only has about 1,500 miles on it. It's drinking about a quart every couple of hundred miles. I've replaced the intake gaskets aswell. When I pull the spark plugs they looked oil baked.
I'm thinking it's either the seals or guides in the head. Would it be possible for it to use that much oil, through the seals/guides???? I barley drive the car know because of this. I hate sitting at a light and the car is puffing smoke.
Neal
Old Jan 31, 2004 | 05:00 PM
$hawn's Avatar
What color smoke is it, and does it smoke the whole time you drive, or just at idle/and or acceleration? Sounds like the valve seals need to be changed, but we need a little more info still to be more sure.
Old Jan 31, 2004 | 05:12 PM
snakeatinZ's Avatar
knock on wood.. ... cracked or warped head??
HectorM52
Jun 23, 2016 08:42 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
blac94Z
Jan 12, 2015 05:44 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
