Help me find my oil leak
Old Jan 13, 2004 | 01:23 AM
CrippleFightin's Avatar
I have an oil leak and I cant seem to find it. There is oil dripping off the sway bar, but then there is also oil on my Y-pipe right about where it connects into one pipe. I have to add oil about every 2-3 weeks, about 2 quarts. I recently replaced my water pump, can oil leak from anywhere on there? Any suggestions?
Old Jan 13, 2004 | 02:35 AM
FacelessZ's Avatar
Have you removed the emissions? I'm assuming its not the oil pan gasket...maybe the timing chain cover?
Old Jan 13, 2004 | 03:50 AM
Zeueses 97 RamAir's Avatar
thats mine to
Mine is to it is close to the right side i bet its the rear main seal and the pan mine drips when my oil gets old.. rear main seal is a bitch to repalce you have to drop the tranny a little... try putting new oil in it see waht it does...
Old Jan 13, 2004 | 05:05 AM
QCKZ28's Avatar
could be: crank seal, timing cover,
check the back of the intake
jesse
Old Jan 13, 2004 | 01:02 PM
I have removed the emissions. I have my LTs with no cats no A.I.R and the egr is "connected" but has an exhaust leak from it.
Old Jan 13, 2004 | 02:04 PM
CamaroBoy96Z28's Avatar
I'd suspect the portion of the timing cover where it meets the oil pan. I have a little bit of buildup there on my car but no leak. Try wiping/cleaning off the area and see what happens.
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
Jessie4tin
Jan 7, 2015 08:53 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
