Help me choose a roller rocker.
If you think you may have any "cam" plans down the road get the 7/16 version and studs to start with. To install guide plates you will need to remove the studs anyways. A set of ARP studs are not all that expensive and being able to do your first lash adjustment on new studs makes it that much easier(no binding or catching). The factory crush nut usually boogers the threads enough that the poly's will not turn smoothly by hand. 3/8 to 7/16 is a big increase in rigidity but not much more money and the rockers cost the same.
