Help Me!!!!
Old Dec 1, 2005 | 01:40 PM
projectcam's Avatar
Help Me!!!!
I just put in a Gm 847 cam 1.6 RR's new lifters and pushrods. When I went to start it up initailly, the car started right up but I had to give it gas to keep it on. Well, I boke in the cam for twenty minutes and shut it down. I went to try and start it back up and it took forever to get it going. I decided that the rocckers needed to be adjusted and I even pulled of the intake to do it. When I put it back together, it didint start at all! Its on a stock tune 97 f-body. I also deleted the a.i.r and egr sytems. What the hell is wrong with this thing. I have checked the spark, good fuel pressure( plugs are fouled. My oil even smells like gas. I checked every vacumm line as well. I really need some opinions guys. I am at my wits end with this thing. I also changed out my springs to K-800's. My car is also having trouble turning itself over. My battery is kept at full charge with a charger. It is also coughing at me through the intake.
Old Dec 1, 2005 | 03:03 PM
projectcam's Avatar
Re: Help Me!!!!
Any ideas anyone!
Old Dec 1, 2005 | 04:09 PM
1997formula's Avatar
Re: Help Me!!!!
It sounds like your rockers are to tight.
Old Dec 1, 2005 | 04:21 PM
projectcam's Avatar
Re: Help Me!!!!
Really, How can I readjust them if the lifters are aalready pumped up. I have adjusted these things three times already. I am 99.9 percent sure the cam timing is correct. I was able to start it before but now it just turnes over and fouls my plugs
Old Dec 1, 2005 | 05:13 PM
projectcam's Avatar
Re: Help Me!!!!
Come on guys, Nobody know this stuff!
Old Dec 1, 2005 | 05:17 PM
jasons93z's Avatar
Re: Help Me!!!!
loosen them up pretty loose, not too much. Start the car, and adjust them by sound. Tighten them until each one stops ticking then turn it another 1/2 turn.
Old Dec 1, 2005 | 05:34 PM
projectcam's Avatar
Re: Help Me!!!!
Thanks for the reply, I can start the car anymore. That is my problem.
Old Dec 1, 2005 | 06:05 PM
jonesy's Avatar
Re: Help Me!!!!
I had the same problem with my Ford GT after cam swap, don't know how fussy the gm's are but mine started right up aswell but after a few minutes ran like crap and was a mother to start. I will be doing some major mods to my 94 Z28 and will be sure it will need a tune aswell.
jonesy
Old Dec 1, 2005 | 06:09 PM
projectcam's Avatar
Re: Help Me!!!!
jonesy
WHat did you do to fix it?
Old Dec 1, 2005 | 06:23 PM
Guest47904's Avatar
Guest
Re: Help Me!!!!
Compression numbers? How about checking for dead cylinders?
Old Dec 1, 2005 | 06:33 PM
projectcam's Avatar
Re: Help Me!!!!
I havent done a compresion check yet. How could one of the cylinders be dead.
Old Dec 2, 2005 | 10:10 AM
projectcam's Avatar
Re: Help Me!!!!
I really need help guys, any ideas will be appreciated.
