HELP! Master troubleshooter needed! Injuneer, Shoebox, anybody!
Old Oct 8, 2003 | 11:02 AM
  #16
multicar's Avatar
Pull all spark plugs and run a compression check...someone may have overshot some nitrous before hand. Then you'll know if the block has to come out or not.
Doug
Old Oct 8, 2003 | 11:04 AM
  #17
GOATCRAZY's Avatar
Originally posted by KGRESOCK
Do you have a cat on the vehicle?
Yes, true duals front to back w/ 2 cats
Old Oct 8, 2003 | 11:11 AM
  #18
GOATCRAZY's Avatar
Originally posted by OutKast
Possibly a bad fuel pressure regulator - Have you checked the pressure on the rail? This could cause your rich condition
Possible bad MAP sensor - if it's at all faulty, the computer will not calculate fuel correctly. The 93's are more sensitive to bad MAPs since we don't use a MAF to measure how much air is comming in.
Send me your DM files and I'll have a quick look for you.
Fuel press. regulator - No gas in vac line, Checked fuel pressure: 43 PSI key on, 38 PSI engine running. NO drop at all after 10 minutes ignition off.
Map sensor was checked, from atmosphere to full vacuum, readings were in line with service manual, I will re-check to post some data.....
Old Oct 8, 2003 | 11:23 AM
  #19
It isn't an issue of whether the MAP sensor is working correctly. All you are doing by testing output vs. vacuum is whether the sensor is healthy. But if you only have 10"Hg vacuum, your MAP readings at idle are way too high. MAP = BAR - vacuum. I suspect you are getting 65-70kPA at idle (20"Hg) MAP readings. That is way too high.
The question is why?
Old Oct 8, 2003 | 11:30 AM
  #20
GOATCRAZY's Avatar
Originally posted by Injuneer
I can only look at the DataMaster files if you have them in .csv format. I can give you an e-mail address to send them, if they are in that format.
The things that stand out are the irrational values you get with the timing light (you should only see 18-20deg at idle , and yes, there is no reason you should see 60-deg), the 10"Hg vacuum, and the 160 IAC count. Have you checked the valve adjustment? Have you verified lift on the cam (badly worn lobes)?
Maybe I missed it in your list, but have you ever done a compression and/or leakdown test?
Honestly, I've stayed away from MAJOR mechanical diagnostics, other than observing all valves in operation, because of the sequence of events is always the same. He woke up in the morning, and the car wouldn't start, and had no problems before that...(Other than the previous no-start condition).
Plus I asked very specifically, did he have ANY driveability/loss of power problems leading up to these incidents, and he said no...But, of course I'm willing to try ANYTHING to get this car running?
Anybody think dropping the cats & running open exaust to check for plugged cats is worth a try?
Old Oct 8, 2003 | 11:37 AM
  #21
GOATCRAZY's Avatar
FYI-----
Datamaster files in .csv format have been e-mailed to shoebox, injuneer, and outkast
Old Oct 8, 2003 | 12:01 PM
  #22
multicar's Avatar
Fuel Injectors clogged with something? I've seen a clogged cat on another camaro and it started fine....after a few mins, then the idle speed would decrease, and then car would barely go over 45mph.
Doug
Old Oct 8, 2003 | 12:03 PM
  #23
GOATCRAZY's Avatar
Yes, you are completely correct, I do see ~ 20 "hg at idle which 29.8?-9(observed w/vac guage) = ~ 20.8. Which means that the low vac condition the the "computer" senses is real....
Would it be worth-while to buy a spark checker and check spark output more qualitatively?
WHy does the datamaster show an injector #1 AND #2 fault?
I also noticed that the knock counts were counting like crazy.....But the ignition did not (appear) to retard.....
Taction control was not active...
I turned of the lights in the garage & did not see a light show....
Old Oct 8, 2003 | 01:32 PM
  #24
KGRESOCK's Avatar
MY .02
Hook up a vaccuum gage to intake vacuum.
Observe value at idle...rev to 2,500 rpm is vacuum
is lower than idle value, cut off the cats.
I think your cats are plugged.
Good luck
Kevin
Old Oct 8, 2003 | 01:35 PM
  #25
Dan K's Avatar
Send me the actual datamaster files...I have a copy of the DA3 version. I'll see if anything stands out.
Old Oct 8, 2003 | 01:43 PM
  #26
turbo_Z's Avatar
if you dont mind sending the .csv file... ill take a look.
Old Oct 8, 2003 | 07:59 PM
  #27
GOATCRAZY's Avatar
O.K. Here's an update:
Went out tonight, and removed the fuel rails..Inspected the injectors, physically they looked good. RE-connected fuel lines, and pressurized the fuel rail. No injectors were dripping.
Held injectors over holes and cranked engine, all the injectors were firing evenly. Put new o-rings on and replaced assembly.
Started car & idled. Put an o-scope on the lo-res and hi-res signals from the opti-crap.
The high-res was evenly spaced, nice & clean signal. The lo-res had the 4 various length pulses and the overall signal looked clean.
Checked the output of the ECM to the ICM module, again, signal looked extremely clean.
Re-checked timing with timing light: appears to be ~ 30 deg idle. Jumps to ~55 when gas is given ??
By oscillating the throttle, I can get the car to rev to 2500 RPM. Timing was at ~30 degrees @ 2500 rpm.
Car backfires after letting off the gas....
I cut the car off. I noticed that the exhaust manifolds (BOTH) were CHERRY RED.....
WHat does this mean???
Where should I go next???
Old Oct 8, 2003 | 08:30 PM
  #28
jonaddis84's Avatar
Man, I think your car is possesed!!
Old Oct 8, 2003 | 09:12 PM
  #29
Vader's Avatar
My thoughts, for what they are worth, is that you need to ignore all that has been done, and diagnose with a clear head.
I may have missed it, but do you have any O2 sensor data?
Also, have you confirmed that the timing chain has not jumped a tooth?
Good luck, it can and will be fixed, because as they say, "its just metal...."
Old Oct 8, 2003 | 09:18 PM
  #30
Red manifolds, IMO takes it back to too much fuel. The excess fuel is burning outside the head when it hits the manifolds. As I said before, the MAP is way high. The pcm would consider this a high load and likely add the fuel. Gotta figure out if the sensor is the problem or something is causing it to read like it is.
How about a test to fake out the sensor?
Do you have a Mityvac or similar? Remove the MAP sensor and plug the hole in the manifold. Apply about 20" of vacuum to the sensor with a hose and your Mityvac. Crank it up and see what happens. Can you monitor it with Datamaster when you do this?
