help... LT header installation
Old Nov 23, 2005 | 11:33 AM
CHELOZ28's Avatar
Okay guys here is the problem, we were doing a header install in my buddies 94z28, Btw these are Pacesetter Long Tubes. Well We finally have them installed but, what can we use to cap off the A.I.R holes in the headers?
Old Nov 23, 2005 | 03:00 PM
CamaroSS30thAnn's Avatar
Re: help... LT header installation
im not sure of teh thread size but just find a bolt fat enough to fit and uses some thread sealer so it wont leak
Old Nov 23, 2005 | 03:11 PM
CHELOZ28's Avatar
thanks, will any bolt work?
Old Nov 23, 2005 | 03:29 PM
IROCARMY's Avatar
Also you can try pipe end caps (plumbing) section.
Old Nov 23, 2005 | 05:38 PM
3gc's Avatar
3gc
If you put the AIR injection stuff on the header you can remove the check valve and use a 1/2" pipe cap. Or you can use a M22 drain plug bolt. I found one in a small auto parts store near the HELP section.
Old Nov 23, 2005 | 06:49 PM
CHELOZ28's Avatar
SWEEET Thanks Guys,
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
