Help with Low Vacuum Problem?
Old Dec 15, 2005 | 09:46 PM
  #16
OBE1 95Z28's Avatar
Re: Help with Low Vacuum Problem?
The 93 style intake PVC system isn't causing your issue, just means you need to check for vacuum leaks in the U shaped tube that provides vacuum to your PCV.
Old Dec 15, 2005 | 11:15 PM
  #17
Deenasty's Avatar
I replaced the U shaped tube today, with no luck.. I mean does everyone agree that my car should be idleing at about 50 kpa, and not the 63-67 kpa its at right now? I mean I dont want to be chasing a problem that is not there...
Old Dec 15, 2005 | 11:23 PM
  #18
SStrokerAce's Avatar
Unless your compression is not what you think it is...
Are the rings broken in yet?
Did ya check the lifter adjustment?
Old Dec 15, 2005 | 11:24 PM
  #19
Deenasty's Avatar
no the compression is what we think it is. The rings are broken in. I readjusted the rockers with 1/8th turn past zero lash..
Old Dec 16, 2005 | 04:27 PM
  #20
Deenasty's Avatar
Bret please chime in and tell me how much vacuum this cam and setup is suppose to make, so that I dont chase a problem that is not there...
also does 30° of timing at idle seem to low? Perhaps im losing vacuum there?
Old Dec 17, 2005 | 03:32 PM
  #21
Deenasty's Avatar
Bret you have mail..
Old Dec 17, 2005 | 04:11 PM
  #22
Kevin Blown 95 TA's Avatar
If the cam is timed wrong, that can do it. If you suspect a valve, connect an analog vacuum gauge and look for the needle bouncing. If it bounces, disconnect the coil, open the the throttle body blades and listen while someone cranks the car. If you hear a woosh sound, it is an intake valve staying open. You can listen in the exhaust or feel the exhaust pulses to see if it is an exhaust valve.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
CARiD
Jan 27, 2015 06:27 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
