Help!! Low Oil Pressure After Clutch Change
Old Nov 10, 2005 | 08:42 AM
charlezd71's Avatar
Unhappy Help!! Low Oil Pressure After Clutch Change
Okay, had the clutch changed and now the oil pressure is huvering just above the red. It took about a month to do it though. Before the clutch change the oil pressure was 3/4 of the way up the guage and right after it was just a quarter of the way up. now the Z has a few miles on it to say the least but I would like to check on any of the simple things first before I pull the pump. Thanks in advance for the help. Oh by the way the car is a 94Z M6.
Old Nov 10, 2005 | 09:04 AM
belac350's Avatar
Re: Help!! Low Oil Pressure After Clutch Change
When you took the trans out did you tip the engine? If so maybe you bent or broke the oil pressure sender.
Old Nov 10, 2005 | 09:25 AM
charlezd71's Avatar
I was thinking it might be the oil pressure sending unit. I think that it is on the back of the intake rite. I will take a look at replacing it this week end.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
