help knock module
Old Jul 18, 2005 | 10:51 AM
Zjoker's Avatar
Question help knock module
Does anyone know which knock module this is the part number for 16188709 and if it will or will not effect performance when compared to the LT4 module. help
Old Jul 18, 2005 | 03:21 PM
diehardgm's Avatar
Re: help knock module
It is for a 94-95 caprice with a 4.3l v8. I would not use it if I were you. This engine is a lot lower compression wise so I am sure it wont detect the same spark knock as the LT4km.
Old Jul 19, 2005 | 10:49 AM
madwolf's Avatar
Following that logic, an LT4 knock module is definetely not OK to use in an OBD1, correct?
Let's see:
Intended for LT4 engine
Intended for DUAL knock sensors
Intended for OBD2 computer
Yet somehow tons of people still use it in 94-95 OBD1 cars, ranging from a Camaro to a 4.3 Caprice.
Beleive it or not, switching from that knock module to a module for that year will not make much of a difference. You can put it on the dyno and compare them side to side if you wish.
Old Jul 19, 2005 | 12:01 PM
Zjoker's Avatar
Does it have any type of effect on tuning?
Old Jul 19, 2005 | 12:03 PM
madwolf's Avatar
No.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
