help knock module
Re: help knock module
Originally Posted by diehardgm
It is for a 94-95 caprice with a 4.3l v8. I would not use it if I were you. This engine is a lot lower compression wise so I am sure it wont detect the same spark knock as the LT4km.
Let's see:
Intended for LT4 engine
Intended for DUAL knock sensors
Intended for OBD2 computer
Yet somehow tons of people still use it in 94-95 OBD1 cars, ranging from a Camaro to a 4.3 Caprice.
Beleive it or not, switching from that knock module to a module for that year will not make much of a difference. You can put it on the dyno and compare them side to side if you wish.
help
