Help with intake bolts
Old Mar 16, 2009 | 06:13 PM
dubbsix's Avatar
Alright! Got the intake on but noticed that when i was installing the intake manifold bolts.. I was short one bolt, and I had one stud that seemed too tall up top, and shorter than the rest..
oye! Could someone post a picture of their intake with bolts or a picture of the bolt set?
Is the stud for the alt bracket longer than the rest of the studs that go into the intake?
Also, does sealer need to go on the threads? I didnt see the factory manual recommend sealer.. but just want to be sure
Old Mar 16, 2009 | 06:32 PM
ulakovic22's Avatar
No sealer and go to www.shbox.com and you can find plenty of pictures. Hopefully you will find them before I can post them
Edit: Too late
Old Mar 16, 2009 | 07:28 PM
You should use thread sealant on the bolts. They go through to inside the valve covers and are exposed to oil on the other end. This will help stop any oil from migrating out.
Here is another pic of intake bolts.
Old Mar 17, 2009 | 12:37 AM
dubbsix's Avatar
Thank you. So from the picture it looks like the second bolt on the passenger side IS longer than the rest of the studs.. is that correct?
Looks like I have the bolts out of position.. and thats why i ended up with a stud on the very last bolt position on the passenger side. I just wasnt sure that the longer stud was actually supposed to go into the intake
Old Mar 17, 2009 | 12:44 AM
deerslayinrenek's Avatar
im pretty sure that the one for the alternator bracket is a little longer than the rest...you will know if you try to put the bracket on.......Good Luck
Old Mar 17, 2009 | 06:53 AM
Yes, just as the pic shows.
Old Mar 17, 2009 | 10:07 AM
dubbsix's Avatar
Thanks.
Old Apr 14, 2009 | 11:40 AM
12sec97Z28's Avatar
This may be because I'm still noobish to engine dis/reassembly, but a good tip is to get a shoebox or larger cardboard box. Punch holes in the box with a screwdriver and put the bolts in those holes, labeling what they are and where they go. My friend is an engineer, so he is way more **** than me, and he actually drew pictures of the intake, heads, etc., and put the bolts where they went on the drawing. LOL. Helping me out a ton with bolts, pushrods, and brackets.
Old Apr 14, 2009 | 06:44 PM
You mean like the link I already posted above in post #3?
Old Apr 14, 2009 | 11:38 PM
12sec97Z28's Avatar
Haha. Honestly did not look at the link until you said that. Great minds think alike I guess.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
rcajun86
Jan 30, 2015 01:56 PM
thenewkid
Nov 27, 2014 09:41 AM
