help identify heads
Old Jun 11, 2006 | 01:17 AM
seawolf06's Avatar
help identify heads
Just wondering if anyone here could help me identify these heads, mainly as aluminum vs. iron, but also if they're the stock heads or not since I was told this motor has been rebuilt.
Outside of driver's side head: 75381A
Inside of driver's side head: 8337 and 10207043
Inside of passenger side head: 8337 and 10307623 (kinda hard to read)
Thanks.
Old Jun 11, 2006 | 01:28 AM
2fast97z's Avatar
Re: help identify heads
well if they are aluminum they are a HELL of a lot lighter than iron but other than that i dunno..ill go look at my heads in the morning and see if they are the same
Old Jun 11, 2006 | 01:29 AM
seawolf06's Avatar
I haven't taken them off to check the weight.
Old Jun 11, 2006 | 01:38 AM
MachinistOne's Avatar
If you cant tell by the color, take a knife and try to scrape some material off, if it is cast iron, you will not be able to.
Old Jun 11, 2006 | 01:46 AM
Originally Posted by seawolf06
10207043
10307623
If you split the difference of those numbers, they may have been read incorrectly(sometimes the numbers look similar) You can get a:
10207643...94-96...350..........Gen.II LT1, aluminum, reverse
flow cooling, 175/68cc port volumes
Which is correct for a camaro lt1
Old Jun 11, 2006 | 01:57 AM
thesoundandthefury's Avatar
A real quick and easy way to distinguish iron from aluminum is with a magnet. If it sticks, it's iron, if not, aluminum.
Old Jun 11, 2006 | 02:03 AM
seawolf06's Avatar
Well the ouside looks like aluminum, but the inside looks like a copper coating or something. I'm pretty sure I read the driver's side correctly, the PS was more difficult. I'll try the magnet thing later, didn't think of that and it's so simple.
Old Jun 11, 2006 | 03:13 AM
I'm sure they are aluminum, that copper color just means that someone has been using pennzoil crap in that motor, it always leaves that residue behind.
Old Jun 11, 2006 | 03:17 AM
seawolf06's Avatar
yeah, the owner before me did, at least it was synthetic. Anyway to clean it off?
Old Jun 11, 2006 | 03:20 AM
1racerdude's Avatar
Get a 3/5 gallon bucket of carb cleaner(soaking kind) and brush some on the head and stand one end in the bucket,after an hour or so flip it over and do the other side.
The stuff is expensive but they will look like new.
Old Jun 11, 2006 | 11:24 AM
seawolf06's Avatar
I'm not taking the heads off, but thanks for the idea.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
