Help I Snapped Another Bolt..this Time In The Head!!!(pic)
Old Jan 16, 2008 | 09:07 PM
playa7970's Avatar
Unhappy Help I Snapped Another Bolt..this Time In The Head!!!(pic)
man will this nightmare ever end.... i was just about finished putting my car back together when..... me that has a over torquing problem snapped another bolt this time in the head.... the bolt i am referring to is the valve cover bolt please any input would be great
Old Jan 16, 2008 | 09:10 PM
Cook Performance's Avatar
buy a torque wrench! It will save you these types of headaches.
Old Jan 16, 2008 | 09:12 PM
playa7970's Avatar
trust me i am after this lol
I have had good luck with reverse drill bits. If that does not work use an extractor. Be very careful not to get metal in the engine.
Old Jan 16, 2008 | 09:14 PM
JasonK94Z's Avatar
an easy-out should get it out for ya.
Old Jan 16, 2008 | 09:15 PM
playa7970's Avatar
whats below that shaft though if i drill all the way through will those metal shavings fall into the engine??
Old Jan 16, 2008 | 09:25 PM
If you buy a set of reverse drill bits, I have a snap on set, they will work for you and most times in a case like this you will not drill all the way through the bolt. That bolt is not locked in very tight. I can almost guarantee if you get a set, they will work and you will use them time and time again. Buy a kit with the reverse drill bits and extractors in one kit. This way if the bits don't work you have a hole drilled for the extractor that is the correct size for the hole.
USE A CENTER PUNCH BEFORE YOU START DRILLING!!!!!!!!!!!!
Old Jan 16, 2008 | 09:30 PM
playa7970's Avatar
can this be bought at like a home depot?
Old Jan 16, 2008 | 09:32 PM
GMRL's Avatar
What he said.
Those bolts dont need much torque, how hard were you cranking on i?
Old Jan 16, 2008 | 09:35 PM
If you can't get your hands on a Snap On or Matco set, I would probably go to sears and get a craftsman kit.
Old Jan 16, 2008 | 09:36 PM
playa7970's Avatar
i was using my ratchet and it just didnt feel snug so i kept going and snappppp
Old Jan 16, 2008 | 09:39 PM
ssbowtie1's Avatar
Just use 1/8" ratchets that way you have less leverage with your gorilla arms
Old Jan 16, 2008 | 09:49 PM
playa7970's Avatar
lol man this sucks its the last bolt too all the way in the back i cant get my drill in there
Old Jan 16, 2008 | 09:56 PM
Green96Z's Avatar
Ouch. Guess you're gonna have to pull the head...
Old Jan 16, 2008 | 10:04 PM
playa7970's Avatar
no way there has to be another way i can get my dremel in there
