Help i have a leak....
Old Aug 2, 2010 | 08:27 PM
a4z28's Avatar
I have found that there is coolant dripping and sitting on the timining cover directly over the throthle body.I see it dripping but cant tell from where? Besides the line on the paasenger that has coolant going to the t.b is there any other spots that has coolant. Does the intake have coolant traveling through it, i think it could be leaking from there. The car does not run hot but i noticed the leak today. I might try to delete the coolant to the t.b and see if that fixes it but the line looks ok from the top maybe there is a dry spot underneath that is causing it to leak? I might just pull the intake or the t.b and put new gaskets. What do you guys think?
Old Aug 2, 2010 | 10:57 PM
There is no coolant running through the intake, just the bottom of the TB. Do the TB bypass and maybe some new hose.
Barrystheman
Jun 25, 2013 05:09 PM
1nicelt1
Jun 12, 2009 03:20 PM
RallyRed701/2
Aug 20, 2007 07:15 PM
Critter
Jan 24, 2006 05:09 PM
