Anyone elses ceramic headers rusting?
Old Aug 2, 2010 | 09:55 AM
havoq's Avatar
It's been about 6 years since I've had em done..but are they supposed to rust? I never drive my car and sits in the winter, so maybe thats why. Just figured they wouldn't. Any way to clean them up?
Old Aug 2, 2010 | 10:20 AM
GRIDERMAN87's Avatar
mine are showing a little surface rust, around where the primary tubes come off the motor, but is not bad just surface, i guess you could sand on them and maybe throw a little high temp paint on them but its gonna come off eventually, im just gonna live with mine they were to hard to put in for me to ever wanna take em off
Old Aug 2, 2010 | 10:43 AM
purple 95 z28's Avatar
Mine have a little rust by the collectors. but that is expected.
Looks like you need a new plug wire lol
Old Aug 2, 2010 | 10:56 AM
razor02097's Avatar
wow 6 years? That is good from what I heard most ceramic coated headers last about 4 years before rusting
example...
http://www.ls1.com/forums/showthread.php?t=97697
If it where me I would go ahead and use a scotchbrite to rub off the rust and hit it with VHT silver header paint.
Old Aug 2, 2010 | 11:37 AM
RamAir95TA's Avatar
Remember ceramic coating is for heat retention and dissipation, not corrosion resistance. I'd say 6 years is pretty damn good. Mine lasted just under two.
Old Aug 2, 2010 | 11:38 AM
lildemars09's Avatar
I just brought these used hooker headers and they had the rust by the collectors and a lil spotting on the primary tubes. I sanded them all down to where it was smooth again and I sprayed them with a high temp primer and I did about 3 coat of that then I sprayed them with a high temp header paint I got at auto zone and I sprayed them with 3 coats and they turned out way better. I've got pics if you guys wanna see
Old Aug 2, 2010 | 11:46 AM
havoq's Avatar
I'd be interested, thank you! I think that sounds like a great idea..and I need to do that.
Old Aug 2, 2010 | 12:08 PM
Jon_Esslinger's Avatar
Here's my Pacesetters after 2 years.
Old Aug 2, 2010 | 12:10 PM
alright I'll have to do it once I get home bc my phone won't put them on here so as soon as I get home I'll put them on. They turned out nice, I just hope they work. Which I believe they will. I'll put the before and after pictures on. Also, I just painted them like 2 days ago. I just didn't bake them like you should. I don't have a baker to bake them in
Old Aug 2, 2010 | 01:25 PM
brucer's Avatar
your plugwire is toast
Old Aug 2, 2010 | 02:12 PM
havoq's Avatar
Ya I know.. I think its been like that for a few years. I just noticed it the other day. Gotta buy a whole new set...can't just buy one. Sux
Old Aug 2, 2010 | 09:07 PM
Also make sure you prep them well if you are going to repaint...or the paint will flake off. A lot of the paints hi-temp paints I have seen also require you to heat them for certain lengths of time to set them up correctly. Other than that good luck!
Old Aug 2, 2010 | 11:35 PM
Alright ive tried everything to post these pictures of my painted headers and its not working. how r u guys posting them
carguy0119
Apr 11, 2016 11:11 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
WildRidez
Mar 27, 2015 08:22 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
