Help..i can actually c a spark
Old May 19, 2004 | 09:05 PM
94zLT1's Avatar
when looking at my spark plugs while the engine is running..one of them i can see a spark jumping from the metal heat shield over it to the plug...drives great..no SES light...what is this and should i do something about it?
Old May 19, 2004 | 09:10 PM
Arc due to spark energy leakage. If it is coming from the boot, try some dielectric grease on it. If it is jumping off of the wire, it probably has some slight damage that is letting the spark leak out.
Old May 19, 2004 | 09:20 PM
94zLT1's Avatar
it looks like its sparking off the actual plug to the metal boot sheild
Old May 19, 2004 | 09:22 PM
If it is not creeping out from under the boot, then maybe you have a funky plug.
Old May 19, 2004 | 09:30 PM
94zLT1's Avatar
when the engines cold should i just unscrew it and screw it back in? thanks shoebox
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
