HELP Hub Problems!!
Old Apr 1, 2004 | 12:36 PM
c0rey's Avatar
HELP Hub Problems!!
I cannot get it off for the life of me. Ive tried this puller and everything it seems to be very solid... Can anyone help me out here??
http://images.cardomain.com/member_i...42_28_full.jpg
Old Apr 1, 2004 | 12:55 PM
QUASARBLUEZ28's Avatar
Hard to tell from the pic but it looks like you are trying to push off the hub itself. You need to get a longer hub bolt than your stock one, and install that into the pilot hole until the threads bottom out. (wont rip apart any threads this way). Use the longer bolt to pull the hub off from. A little P. Blaster fluid never hurts either.
They are a pain to pull initially, but easy once they've been removed.
Old Apr 1, 2004 | 01:44 PM
c0rey's Avatar
So i need to get a bolt longer than the bolt that holds the hub on and put it into the hole and then pull on the hub then there will be enough slack in the bolt to break the hub loose?
Old Apr 1, 2004 | 01:55 PM
LS1_03's Avatar
Yep.
1996LT1Z28
Apr 14, 2015 07:15 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
