HELP how to fix no start in rain???
Old Mar 17, 2005 | 11:42 AM
LenT1's Avatar
This is the 2nd time my car won't start when its wet/raining out. This time I was driving and went to take off and it stalled and wont restart, now its pushed off the road 3 blocks away. I can't have this, I just got a tune-up too. What causes my car not to start in the rain and how can I go about fixing it? Any answers would be of great help. Thanks in advance.
Old Mar 17, 2005 | 12:13 PM
Brian Sutherland's Avatar
Re: HELP how to fix no start in rain???
I would bet its your ignition coil or ignition wire. Mine did the same thing a year ago and that was the problem.
Brian
Old Mar 17, 2005 | 06:41 PM
LenT1's Avatar
I just got new wires though..
Old Mar 17, 2005 | 06:59 PM
#7's Avatar
Beats me! My wifes v6 camaro does wierd stuff in the wet also.Gives SESs (non memory ones hmmm) shifts hard,shows low oil (oil full) wierd stuff ???? The car is fine though even when acting up...I dont know yet. Sorry
I have even looked at various sensors,because my immediate concern was a moisture issue, and found no weather packs or anything really getting wet. The symtoms go awy and so does the concern too ...because after all this problem doesnt really affect drivability and nothing is REALLY wrong .
And Len what Brian mentioned was ignition coil not the wires apples and oranges dude. I'd look into that if I were you same symtom could get lucky and that be it. They are cheap enough
Old Mar 19, 2005 | 11:22 AM
ChickenScreamer94's Avatar
There is a ground lug on the passenger side strut tower. It is next the little red postive terminal. It has the ground wired for the starter, ECU, and other things. It rusts and doesnt ground well after time, especially when wet. Remove it and clean the grounds well (disconnect the battery first). Reassemble.
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
