Help with Hissing sound from rear
ok well i have been away at school so i havent had time to check my car for problems etc..drives like a dream though..anyway... as im pulling into my driveway at home my ABS INOP light comes on and stays on...so i pull it up on the ramps and i hear a hissing noise from the rear...like air being let out of a tire but constant and slow...anyway i check the tires its not them then i go under the car and it seems to be coming from the rear end/ fuel filter spot i check the filter its not that....it stays constant and i cant pinpoint it...it dies out after like 8 minutes
I thought it was the fuel filter nut loose letting out the pressure?
any help
any help
Re: Help with Hissing sound from rear
There is a small tank vent attached to the LR brake hose bracket. Could it have been coming from that? I am assuming the engine was off for those 8 minutes it took to go away. If so, it wasn't the fuel pump.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
squarehead
Nov 21, 2014 08:02 PM
