Help Help Help!!!!!
Old Aug 12, 2007 | 04:25 PM
97formulakid's Avatar
Help Help Help!!!!!
Ok, today I was finishing up wiring my linelock/2step/nitrous kit. I got everything wired and started to put my interior back together. As I was putting it all back together I was cleaning it too, I have some interior spray from Autogeek that smells just awesome, I sprayed some in each of my vents because when I run my AC I can smell it and it makes the car smell good.
I checked all the components and everything was working fine, I checked everything more than once and the line lock/ 2step/ and everything on the nitrous kit was working perfect.
I started putting tools away when I heard this clicking sound start coming from the passenger side. It sounds like a relay clicking but it is happening very fast. When I put my key in the ignition it is amplified and has a higher pitched sound, then when I try turning my key on the sound stops but the car won't start and I have no lights or radio or anything. With the doors shut it does not make the sound, only with the doors open. Well I tracked it down and it is coming from some kind of module from behing the glove box. I tried looking at it and it says SIR module and has a bunch of wires running from it.
WHAT DID I DO AND HOW DO I FIX IT!!!!
Old Aug 12, 2007 | 05:04 PM
anyone?
Old Aug 12, 2007 | 07:48 PM
chevyinside's Avatar
dead battery ?
Old Aug 13, 2007 | 10:00 AM
SIR module is for the air bags.
Old Aug 13, 2007 | 10:14 AM
Ok, so what should I do? I am almost positive that when I sprayed the interior cleaner in my vents that it got some on the SIR module. Will it just dry out? Do I need a new one?
Old Aug 13, 2007 | 07:34 PM
sir module is under the center console toward the rear . the bcm would be where you talking about thou.
Old Aug 14, 2007 | 05:29 PM
I'm just an idiot. My battery was dead.........yes, I rode the short bus to school when I was little!
