Help with gear size...
Old Jan 14, 2004 | 01:03 AM
ComputerNerd's Avatar
I am trying to figure out what gears I have.
The rear end was replaced in the car so I can't look at the codes.
I used the only method I knew by jacking the car up, spinning the wheel once, and counting how many times the drive shaft spun.
This lead me to believe I have 3.23s.
Which is what I was told was in the car.
I then used the gear chart rpms/mph and it says I have 3.73s.
My car is an auto with 275/40/17 tires.
At 70mph I'm at 2500rpms.
Anyone know why these two methods give different results...
Old Jan 14, 2004 | 01:32 AM
InjectedSS's Avatar
That's a really difficult way to do it...
Best way to do it would be to pull the rear end cover off.. Then count the teeth on the pinion and then count the teeth on the ring gear... THen you divide the teeth on the ring gear by the teeth on the pinion and you have your answer..
An example for 4.10's would be 41 teeth on the pinion / by 10 teeth on the ring gear = 4.10
Then ring gear is the LARGER one. The pinion will have less teeth.
Old Jan 14, 2004 | 08:49 AM
I was hoping there was a guaranteed way to tell gear ratio without pulling the cover.
I see most people use the rpm/mph chart.
Is there anything that would throw off the rpm/mph chart?
Torque converter not locking for example...
Old Jan 14, 2004 | 08:55 AM
InjectedSS's Avatar
Yea there is a guarnteed way to tell.. Pull the cover off and start counting
Old Jan 14, 2004 | 10:02 AM
bandit1's Avatar
Take your car out on the highway, drop it into the 3rd, and run it at 70mph. If the RPM's are around 27-2800 you have 2.73. If they are above 3000 most likely 3.23. It worked on my car... hope this helps.
Mike
Old Jan 14, 2004 | 10:06 AM
96YenkoClone's Avatar
i would say youd be closer to the 3.73s but thats a guess because i have 3.42 and im not that high of an rpm at 70mph
Old Jan 14, 2004 | 10:29 AM
got_hp?'s Avatar
according to fbody gears if you are at 70mph at about 2400-2500 in 4th gear, then you have a 3.73 rear gear.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
