HELP! Engine still not running right, ideas?
Old Dec 12, 2006 | 05:07 PM
flexus's Avatar
Problem: I have a '96 Z-28 for about 3 months now. Engine always worked **** from the day i bought it.
Changed: plugs, wires, distributor, cleaned injectors (ultrasounds etc), replaced fuel filter, replaced EGR valve, replaced all cooling fluid, put it on tester, checked all sensors (o2, maf etc), spanked it...
Results: Went from banging all over working in 6 cyls to working in 7 cyls to working in 8 cyls but with misfires and banging to working in 8 cyls but just not right...
Right now it seems to be almost stable, except for hickups that happen when i floor it in higher gears (1st and 2nd are too fast to feel anything). Feels like small gaps in power (they are random)... I might say they are felt even when rolling real slow in the form of shaking but i'm not sure it's same thing. I'm thinking lack of fuel but where from? I'd like to know if there may be something else wrong before i take the injectors out again and spank em. Also at idle i can hear the exhaust doesn't have a clean steady sound, fluctuates (but not like before i changed the distributor).
P.S. Car is stock no mods, I use 95 octane.
HELP PLS ...
Old Dec 13, 2006 | 01:13 PM
flexus's Avatar
Also while revving in standstill it can be noticeable that aroud 1500-2000 rpm whole car vibrates and makes a weird low sound, after 2500 engine runs pretty smooth.
Old Dec 13, 2006 | 01:59 PM
transAMdriv3r's Avatar
my car is acting up pretty much like that, had the fuel pressure tested and its running at 34 psi. it should be 41-47...in goes a new fuel pump for me. get your tested. you may find an answer
Old Dec 13, 2006 | 03:47 PM
mrmint69's Avatar
Check your plugs and make sure there tight. Check wires & make sure they are in good shape with no breaks and are not touching anything hot or sharp.
Old Dec 13, 2006 | 04:14 PM
BradcTA's Avatar
x2. Something as simple as a plug wires touching the manifold can cause the sympoms you described.
Old Dec 13, 2006 | 04:36 PM
12sec97Z28's Avatar
x3. Had similar symptoms. Changed the plugs and wires, but wasn't careful enough. Started doing it again a day or so later. Crawled under the car and sure enough, a brand new MSD wire was resting right on top of my headers with a huge burn hole in it. Always triple check the routing of wires and make sure there is NO WAY it can touch the header/exhaust manifold. Changing these wires is too much of a pain to do unneccessarily.
To check it, you can park in a dark garage and look under the hood for blue sparks around the wires/exhaust manifolds. Sure sign of a burned wire.
Old Dec 14, 2006 | 02:46 AM
flexus's Avatar
I'll be looking into that today... the wires i can check, plugs i can't check tho gotta go to a service.
Can the fuel pressure be tested easily? Can any service do it?
Except plugs, wires and fuel pressure, may anything else be at fault? Valves, vaccum leaks...
Old Dec 15, 2006 | 09:26 AM
flexus's Avatar
I found the problem! Everyone with same issues note possible solution: injector electric plug safety missing... plug getting a little loose, missing signals while car is vibrating ==> misses and power loss.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HCz28
Jan 11, 2015 11:21 AM
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Absolute Z28
Jul 19, 2002 02:21 PM
