HELP !!! Engine Revs up when in Gear and hot !!!
I've got a 94 Automatic LT1 that's been having this problem for quite a while now. When the engine's hot (halfway) and in gear (at lights) the engine revs up and this leads to the car jumping forward. Taking the trans out of gear (N or P) makes it stop.
I've replaced the O2 Sensors, I've replaced the IAC valve and EGR valve hoping that it'll solve the problem. Actually, it worked fine for a couple of weeks after the EGR was put in but returned last week.
Also, I seem to smell Gasoline everytime I get off the car after driving for a while. Any ideas?
Any input will be greatly appreciated.
Thanks for the advise. I will check into the intake and see if there's any leaks. Just a question though ... could this be a problem with the MAF? It does it only when hot (over halfway) and not when cold.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
TheV6Bird
11
Jul 28, 2002 05:25 PM
