HELP Dynoed today wierd numbers????
Old Jul 23, 2003 | 01:20 PM
TexasTechTA's Avatar
I have a 96 TA with mods in my sig here were the numbers
287 hp @5000rpm
315 tq at4400rpm.
The graph is choppy throughout the whole hp and tq curves indicating an ignition problem? I have stock wires and plugs with 67000 miles.
Here is the kicker the AF ratio was pretty steady at 14.8 to 1 very lean. I had the pcm tuned and he leaned the mixture out bc he said most lt1's run rich could that be the problem.
I am gonna do MSD wires and NGK plugs tongiht will that help out at all?
I am actually kind of happy with the numbers considering the misfire and a lean aF what do you think it could make?
Old Jul 23, 2003 | 01:28 PM
Camaro_Maniac63's Avatar
New wires and plugs could help solve your problems. But the thing that stood out to me is that you made 287rwhp @5000rpm, and you have a Hotcam!!!! Most Hotcam equipped z28's make power all the way to ~6000rpm, even higher in some cases. That is what that cam is made for. I think you need some more tuning done to take care of that. I think you have at least another 25-30rwhp out of that setup. Good luck.
Old Jul 23, 2003 | 01:29 PM
Also, was that a Mustang Dyno, or a Dynojet?
Old Jul 23, 2003 | 01:33 PM
I am sorry the hp tops out at about 5700 rpms sorry I misread it.
Old Jul 23, 2003 | 01:35 PM
it was a dynojet not a mustang dyno
Old Jul 23, 2003 | 01:37 PM
That is a little better. Those numbers aren't too bad man, just take care of the small stuff like the plugs and wires, get the car tuned a little better, and you will see much better numbers. Good Luck.
Old Jul 23, 2003 | 01:40 PM
the dude at pcms for less leaned the af out slightly he said should I reverse this or with newe plugs and wires could that fix my AF ratio the AF is pretty steady it dosn't jump much what do yuo guys think?
Old Jul 23, 2003 | 01:49 PM
Wires and plugs won't help the AF, and yes, you might want to make it just a little richer. Rich is always better than lean.
Old Jul 23, 2003 | 01:58 PM
the shoppiness of the graph means igniton problem right? could the maf be malfunctioning? maybe cause of the lean condition?
Old Jul 23, 2003 | 02:52 PM
BradZ28's Avatar
Do you have stock valve springs?
Old Jul 23, 2003 | 03:31 PM
97Z-M6's Avatar
if your saying that the car was running 14.8 a/f ratio at wot throttle. that is way to lean it needs to be about 12.8 to 13.1. he leaned it out way. WAY TO MUCH. in closed loop is 14.7. wot or open loop is factory at 11.7 to 1 af ratio. i personally would not run that car at wot throttle till you get that reprogramed. your running leaner in at open throttle. than in closed loop
hey i will fix it for you at no charge if your willing to meet me half way im only about a hour and a half. but honestly the best thing to do is go get it tuned on a dyno with a wide band 02
sorry just relized your obd2. sorry i tried to help.
Old Jul 23, 2003 | 04:33 PM
they are lt4 valve springs also am IO doing any damage with it being such a lean mixture there is no power adder?
Old Jul 23, 2003 | 05:11 PM
to make a long story short I think the maf was messed up i borrowed my bros off of his 94. Could the MAF make the car lean that bad? let me know thanks
Old Jul 23, 2003 | 05:12 PM
Fastbird93's Avatar
If you've got the hotcam kit with the headers and the rest of that stuff, you should be seeing I'd say at least 310-320. I'd say take the car to a different person to have it tuned.
Old Jul 23, 2003 | 05:17 PM
zhevy-1's Avatar
With the hotcam, it should've dynoed over 300rwhp with no problem. Just need tuning bad.
