HELP!! Dyno Run: This cant be normal!
Old Mar 3, 2004 | 08:54 PM
stang_killa94's Avatar
Angry HELP!! Dyno Run: This cant be normal!
I got 1 run on the dyno today and the results were 237.2 Max power and 267.7 Max torque! Is this normal with CAI, Jet Hot LT's, no cat, flowmaster, and TB Bypass? I mean isnt a stock z28 like 280 hp? Im really down right now, i was hoping for at least 290-300 hp. Also i got a Air/Fuel gauge and im running lean and rich at the same time, is this normal? The gauge goes crazy when i step on the gas and when i let go of the gas it falls down all the way. I think there is something seriously wrong with my car what do you think?
Dyno Sheet
Old Mar 3, 2004 | 08:56 PM
GreenDemon's Avatar
Definitely not right.
Any numbers on fuel pressure and timing???
Need some numbers from the ecm or even a look at the dyno can be helpful, also fuel pressure..
hsyr's Avatar
Is your car hard on gas lately? Maybe your O2s are shot. Maybe the opti is dying or the coil is shot.
Old Mar 3, 2004 | 08:58 PM
ledfootz28's Avatar
arent lt1 rated at 275 at the flywheel and more like 240 sumthin at the wheels?
Old Mar 3, 2004 | 08:59 PM
HBHRacing's Avatar
I dynoed at 256 HP and 297.3 TQ stock.. but I am 10 more hp then you stock but yeah sounds like you ahve a little problem. when was your last tune up?
Cmr0z28's Avatar
O2's wouldn't matter, they're ignored at WOT. Post the dyno graph if you can.
Old Mar 3, 2004 | 09:00 PM
96ta(nick)'s Avatar
check your plug wires...
Old Mar 3, 2004 | 09:01 PM
Thats what i figured at first but even with the few mods i've done i should be doing me than 237!
I'll get the dyno sheet online tonight, How can i find out my fuel presure and timing?
Old Mar 3, 2004 | 09:14 PM
the last tune up was about 2 yrs ago
Old Mar 3, 2004 | 09:20 PM
stereomandan's Avatar
Both numbers are down 20 from stock.
LT1's dyno about 255/290
Look at it this way, at least you found out that there is a problem so that you can fix it and max out the potential of your Z28.
Dan
Old Mar 3, 2004 | 09:31 PM
Dan
yeah that was one of my reasons behind getting the dyno done but now im just pissed that i dont know whats wrong with it
Old Mar 3, 2004 | 09:52 PM
OK here is the dyno sheet, anyone know whats going on? Thanks
Dyno Sheet
Old Mar 3, 2004 | 09:57 PM
I don't know, but DANG that's crazy. Seems like it would be something you could feel with those spikes. Does the car feel smooth?
Sorry.
Dan
Old Mar 3, 2004 | 10:00 PM
I wasnt there when they put it on the dyno but the car doesnt feel smooth at all when i take off until i get to about 2,500-3,000 rpm then its kinda smooth.
Old Mar 3, 2004 | 10:06 PM
speedracer93z28's Avatar
you said you only did one run, right? well maybe your car wasnt warm yet. when i went to the dyno my first pull was 230rwhp my second was 265 and my last pull was 280.
