Help with crankshaft choice
Old Mar 9, 2007 | 11:08 AM
69gto96z's Avatar
I am trying to pick out a crank for my motor. I am boring it .030 over, and just want a nice forged crank to compliment my other forged internals. Am planning to run a 150 to 200 shot on it. I am on a budget, was thinking about maybe a scat. Anyone have any thoughts?
Old Mar 9, 2007 | 11:25 AM
Daniel6718's Avatar
stock crank...it will hold up with forged rods and pistons...
unless you want a stroker...then eagle is a nice piece
Old Mar 9, 2007 | 11:32 AM
69gto96z's Avatar
Yeah I was thinking about keeping the stock crank, but a forged crank would make me feel better about it. I cant have this motor blow up on me. Did u get my text about the w/p?
Old Mar 11, 2007 | 04:16 AM
Daniel6718's Avatar
yep, i dont think youll push that crank hard enough with a 150-200 shot...with heads youll be near 600..still i dont think its the part to worry about, piston/rod/rings are more likely to let go...if you go with a ctroker crank though i think youll still have to notch the block even with i beams, in that case you should buy my eagle rods...and go all out...
but the nice part about a stroker crank is you have more cubes so you can do a bigger cam and it will be more tame....
Old Mar 11, 2007 | 04:30 AM
MachinistOne's Avatar
The eagle parts are junk, tolerances all over the board, and no depth of hardening. If you want a forged crank that is not pricey, get a Scat or Probe. I have used many of both brands, and they are in spec most of the time and are better material than the eagles...not all 4340 cranks are the same
Old Mar 11, 2007 | 05:13 AM
69gto96z's Avatar
Yeah, I think I am just gonna stay with the stock crank.
Old Mar 11, 2007 | 08:01 AM
Guest47904's Avatar
Guest
How do you plan on keeping it together with a 150 or 200 shot? Nothing like puttin the juice to her but not making the bottom end to handle it. Let's not forget the 2 bolt mains either.
Old Mar 11, 2007 | 08:08 AM
Z-RATED94's Avatar
I say go for it, just use ARP main studs and some high quality rod bolts. I need to see if your set-up holds up. That way I can give it a shot (no pun intended) in a couple of years.
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Slayer
Aug 17, 2015 03:55 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
