Help with crankshaft choice
I am trying to pick out a crank for my motor. I am boring it .030 over, and just want a nice forged crank to compliment my other forged internals. Am planning to run a 150 to 200 shot on it. I am on a budget, was thinking about maybe a scat. Anyone have any thoughts?
Yeah I was thinking about keeping the stock crank, but a forged crank would make me feel better about it. I cant have this motor blow up on me. Did u get my text about the w/p?
yep, i dont think youll push that crank hard enough with a 150-200 shot...with heads youll be near 600..still i dont think its the part to worry about, piston/rod/rings are more likely to let go...if you go with a ctroker crank though i think youll still have to notch the block even with i beams, in that case you should buy my eagle rods...and go all out...
but the nice part about a stroker crank is you have more cubes so you can do a bigger cam and it will be more tame....
The eagle parts are junk, tolerances all over the board, and no depth of hardening. If you want a forged crank that is not pricey, get a Scat or Probe. I have used many of both brands, and they are in spec most of the time and are better material than the eagles...not all 4340 cranks are the same
