Help! Coolant leak
Old Apr 10, 2003 | 01:21 PM
joewin's Avatar
Unhappy Help! Coolant leak
I have coolant leak that I think is coming from a seal. I checked the reservoir tank and hoses and they seem ok. Since the leak has been there for a long time I suspect that it is really no big deal except I have to keep adding DEX-COOL every so often. I was wondering if anyone has used a product called "No-Leak". The product web site says it is safe to use with all coolant types. I am interested in hearing from this group on what your experience has been or if you have never heard of it before.
Here is the link, cut and paste to your browser.
http://www.goldeagle.com/no-leak/
1996 Black TA Convertible
Old Apr 10, 2003 | 02:22 PM
Bad T.A.R.A's Avatar
I would pressure test and find the leak. I think that stuff will clog you radiator and builds up in engine short term is okay but to get that stuff out..
Old Apr 10, 2003 | 02:28 PM
z28Power's Avatar
As long as you aren't sure that it's coming from the waterpump. If that bad boy is leaking, you need to replace the water pump asap. You really need to find where the leak is coming from and just replace the seal, as all those additives do is fix the problem short term while causing bigger problems in the long run. In addition, if it's coming from the waterpump your opti is in danger of going out, which is an expensive repair part.
Old Apr 10, 2003 | 02:29 PM
The stop leak additives don't always work and it would be better if you could just find the leak. Rent a pressure tester to help you find it.
Old Apr 10, 2003 | 02:31 PM
94T56T-TOPDREAM's Avatar
Yea you can borrow a pressure checker at a parts store, and find out where the leak is. My radiator was leaking, but it was only $150 for a new one with a life time warranty.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
