Help on compression ratio
Old Dec 20, 2004 | 09:57 PM
93z383's Avatar
I have misplaced my spec info on the internals of my 383. I am doing research to ad possibly a power adder, super/turbo charger. I have KB D dish pistons stock heads no porting yet. with a .030 bore, stock head gasket, how can I determine my compression ratio?
I do not know the cc of the Pistons, I assume they are 5cc.
any Ideas?
Old Dec 20, 2004 | 10:13 PM
442olds's Avatar
Re: Help on compression ratio
Assuming these numbers here's your compression ratios. KB has two dcup pistons one 18 cc and one 28cc and I have it calculated for both for ya there.
Bore = 4.030
Stroke = 3.75
Rod Length = 5.7
Deck height = 9.008
Comp. Height = 1.433
Dcup = 18 or 28
Combustion Chamber (cc) = 54cc
Thickness = .043
Bore Diameter = 4.060
Compression ratio = 10.7 or 9.5
Old Dec 20, 2004 | 11:19 PM
93z383's Avatar
wow now that is service....you are a gentlemen and a scholar.
Old Dec 21, 2004 | 03:54 PM
kmook's Avatar
Advanced Tech Moderator
Bore = 4.030
Stroke = 3.75
Rod Length = 5.7
Deck height = 9.008
Dcup = 18 or 28
Thickness = .043
Stock head gasket size is .049 not .043, also stock bore is 4" with a .030 overbore as he stated results in 4.030 not 4.060...
And 93z383 I can't calculate your static c/r without knowing what your deck height is after the block was machined.
Old Dec 21, 2004 | 05:06 PM
93z383's Avatar
Ok, That too is going to be hard to come by. My block was in very good condition when the machine shop worked on it. I hate to assume anything but for argument sake what is a minimal to average amout of milling done to a block for this type of situation, I am sure the pistons are the smaller of the two options from KB, 18cc. with that I'm probably in the 10.1 to 10.8 range I assume. I'd like to get a close ballpark so once I do something, I can calculate my best option for chamber size etc for a blown application, this is a daily driver but I don't mind puting in the preimium, I do it already.
thanks for the help.
Old Dec 21, 2004 | 11:21 PM
442olds's Avatar
I assumed the gasket diameter was 4.060 not the block diameter, I also guessed on the gasket thickness, but your not going to see that much of a change in cr with the difference in either dimension.
play with this to get static and dynamic compression
http://www.et-motorsports.cc/tech/93z383.xls (right click and save)
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
